Custom keycaps for UHK
Hey UHK community!
My name is Simon from FK, I wanted to let you know that we now support the UHK layout in our keycaps customization app called Yuzu Keycaps.
It’s quite a big deal for me personally as I started my mechanical keyboards journey with a UHK, and still enjoy it some times to this day. It is this exact layout that sparked the idea of making an app where anyone could get just the keycaps they need. That was 5 years ago, and only today is it possible to order them for this specific keyboard…
Anyways, I’m looking forward to hearing what you think of the app and if you are able to get exactly the keycaps you need to match those crazy macros/shortcuts you may have configured on your own keyboard.
This is very exciting, and thanks for the heads-up!
Can you share some photos of the keycap set? I’m sure the community would appreciate it. It would give them confidence and could boost sales.
Absolutely, so let’s start things with a giveaway then!
There are customer reviews on the website too if people want to check out the quality of the keycaps.
@kartsims Just checking something - pretty sure this is a no but well you never know…
The keys on the UHK have labels also printed on the sides (to show what the alternative layers do), when i use your site it does allow me to position text in the bottom area, like this:
But I’m pretty sure that wouldn’t actually work and result in the label “test” being printed on the bottom side like that, is that correct?
Thanks - great news re: the keycaps regardless.
Matt
Hey Matt,
You are right, unfortunately they can’t do that at the moment but I will ask eventually. I created a feature request in case you want to upvote and get notified when/if it becomes possible
Well-done configurator, I am impressed by the options for customizing individual keys.
Two questions:
  1. Is it possible to order individual keycaps, instead of the complete set?
  2. Do you also have an option for translucent/ shine-through caps that allow RGB-backlight through the labels?
Hey Stefan,
Thank you for the kind words!
To your questions we have another service actually called FK Custom that offers both options: individual keys and shinethrough keycaps. I did not mention it before because it doesn’t support the full UHK layout (yet) as we are waiting to be able to purchase blank keycap sets first.
For Yuzu we won’t have the possibility to order individual keys anytime soon however.
Thank you for the speedy response and the link. I appreciate it.
It’s great to have all these additional options. Finding high quality keycaps has always been one of the trickier parts on my quest for the perfect board. Yuzu seems like a very promising complement.
FK Custom has a UHK80 layout!!!
Nothing for the bottom row thumb cluster “Fn2/Space/Mod” though…
I’ve decided to go ahead and experiment with the UHK80 caps. What do ya think?
I added a few extras since I haven’t settled on the location of the “Print” & “Delete” keys.
I wanted to make the whole top of the caps to be shine-through with just the legends and sides of the caps solid black (kind of like an inverted pudding cap). But to do that, I would’ve needed to convert all of the legends to .SVG files… Way too much work…
I did my best to make a nice little inverted pudding Agent cap though :sunglasses:
I don’t know if these will work with the bottom row thumb cluster keys or not because the Fn2 keys use stabs, but it was only $5 extra to add four LPF keys. I figured it’s worth a shot. I’ll let you all know how it goes when they get here…
Love your Agent cap! :heart: :dark_sunglasses: :heart:
Thanks Max! His glasses are a little wonky, but I’ve been awake for almost 24hrs, so good enough :sweat_smile:
I just got some new caps for the UHK80 from FK custom. I actually first ordered them a few weeks ago, but they had some alignment issues. I emailed FK’s support with pics of the issues, and they sent some replacements within a reasonable time. Smoothest support interaction ever, BTW. Super nice guys.
I kept the layout basic because I never know when I’m gonna remap something. I like uniform profile caps, so I went with the XDA shine-throughs.
These shine-through caps are quite a bit more translucent than most double-shot caps. They’re noticeably brighter IRL.
(LEFT= FK LPF & RIGHT= UHK STOCK)
(LEFT= UHK STOCK & RIGHT= FK LPF)
I also grabbed some 1u/1.75u LPF shine-through caps for the bottom-row thumb keys. I wasn’t sure how well these would work, since the UHK80’s “Fn2” keys use stabilizers, and the FK LPF caps only have one center stem mount. The LPFs do rub the stabilizers a little, but it’s not too bad. They work fine if you leave the stabs in, but I went ahead and removed them. They barely wobble at all without 'em. (Even less than the other MX 1.5u/1.75u caps!:grin:)
There’s also not really a problem with accidentally depressing the LPFs, as long as your upper-row thumb caps are tall enough. I didn’t have any trouble mixing either the FK XDAs, or the UHK80 stock caps.
LPF Space Wizard
There is one other issue with the FK LPF “Fn2” caps…
The corner of the caps get stuck on the rubber palm rest. Only just a tiny bit, but enough to where I needed to make a small notch in the rubber so the caps can move freely. You’d only notice if you were trying to see it. I suppose you could just sand the corner off the caps instead of trimming the palm rest, but these shine-through caps are translucent ABS with a black PU coating. (FK also has opaque PBT caps that would be less noticeable with sanded off corners Actually, the LPFs are shine-through only)
Of course, FK also sends you a sampler of some of their other options…
