Scancodes and mouse actions are reported over different USB interfaces, so if they are sent in a rapid sequence, the computer/program may receive them in wrong order.
Solution is to add some delays between the commands. E.g.:
This can also be done globally by setting set keystrokeDelay 10 in your $onInit macro. (Careful with this as keystrokeDelay may cause significant latency with too high values.)
@highend I would like to ask you for more information on this. You can read more on reasons for asking these questions here: Feedback needed: key timing, latency, delays, although reading it is by no means necessary.
What OS are you using?
Can you please test the following version of the macro with various keystrokeDelay values and let me know which is the lowest value that produces reliable results?
pressKey LC-
pressKey mouseBtnRight
releaseKey LC-
Sorry, I didn’t get an e-mail about a new post in this thread…
I’d really like to help out but I’m afraid I unable to do so.
I’ve switched from Windows to Mac (Ventura is currently installed).
I only have Windows as virtualized machines on Proxmox now and things like sending a keyboard modifier like CTRL doesn’t really work via the RDP connection so I’m using an .ahk script on the VM that looks for a specific key press (and I let my UHK send F13… for this).
