Assigning mouse button with shift to a key
Hello,
I would like to assign “shift + middle mouse” to a key, but can’t figure out how to do so. when assigning a mouse button to a key, there is no option for modifiers, and when there is the option for modifiers, there is no option to use a mouse button.
i tried assigning Lshift and middle mouse presses in a macro, but i don’t think i’m getting the behavior I want (left shift and middle mouse pressed as long as the assigned key is pressed).
i found this question:
but it is for a click, not a hold-while-the-button-is-held.
is it possible to have a macro that responds to keyboard behavior, or is it always a set sequence of inputs?
i’m mainly trying to have a single key press for panning in blender (which is shift + middle mouse). as an alternative solution, i tried assigning mouse 6 to a key and to pan in blender, but holding down the key did nothing (i don’t know if the issue is on the blender side or the uhk agent side).
any help would be appreciated.
This should do the trick:
pressKey LS
holdKey mouseBtnMiddle
releaseKey LS
(I am wondering if holdKey LS-mouseBtnMiddle is legal and supposed to work. If not, it should probably throw a validation error.)
that’s exactly what i was looking for! thank you very much!
