Tunney
1
After many years of happy UHK use on Macs a new job has forced me into Windows.
God I hate windows.
Anyways looking for someones example of a working alt code. I like the em dash a bit much!
I thought what I had would work but appears not, would anyone care to share their examples please?
maexxx
2
Here is a macro that types a ¿
You need to bind this macro to the key which you want to produce the ¿ character.
Based on @maexxx’s post, following should do the same thing: tapKeySeq pLA np0 np1 np9 np1 rLA
Tunney
4
Thanks! Both worked a charm, I was stupidly including an explicit numlock press before and after!
