I’m having an issue with my UHK. Since the recent update adding typing behavior, whenever I am typing quickly, after typing a string of around 37-100 characters at a high WPM, characters stop being typed correctly, almost as if I’m typing faster than some buffer can store and offload what is being typed. This will persist until I stop typing, and it will result in more than 75% of keys being typed (once I’ve hit this threshold) not being written for a short period of time. The amount of text I can type without this happening varies, however it that variance is narrow to “not that much text”. Its spotty but consistent
The best way I can describe it is to illustrate it here. Below, I open up a Textedit and type “this is a test” over and over at approx 110 WPM (I typically type at 140 WPM+, but slowed down to ensure 100% accuracy on my end)
This is a test this is t est this is a test this is a test this is a test this is a test this is a test this iset st this is a test this is a est thies si this is a test this is a test this i a test this is a tes thitis
The typos and errors are happening purely as a result of this bug. Sometimes the period in which the characters are not typed last a few characters and sometimes I’ll have have to literally stop typing and pause for it to start detecting keypresses again.
I’ve gone from relying on this keyboard to hardly being able to use it, so I’m hoping that this is a software bug.
My Typing Behavior settings are set to “simple” and have not been modified from defaults.
I’m using UHK v2 I’ve had only or a few months which has never left my desk (I’m confident there’s not hardware damage unless it occurred during or before shipping), keycluster + trackball. Firmware 11.0 on everything. UHK agent 4.0.2. Should be noted that I have a very vanilla UHK setup.
I am using this on the latest macOS Sonoma and a Windows 10 desktop and the issue persists on both, and the issue does not happen at all with any other external keyboards or the Mac’s internal keyboard.
I’ve noticed that removing and readding modules can sometimes “Fix it”, but since the periods of time when the characters stop being written varies so much, then the modules as a root cause might be straight up placebo.
I’m happy to undergo any troubleshooting steps, so if anyone needs additional information, please let me know.
Any tips?
