I’m working on home-row mods, experimenting with different timeouts.
What would be great is to see an indicator when a secondary role has been triggered. I know I can do that by binding macros on each and every key that has a secondary function, and updating the LED display in the macros depending on primary or secondary invocation, but that is tedious when I would need to do this for 10+ keys.
Is there a more clever trick to show something when a secondary function triggers on any of those many keys?
Would it be a helpful firmware feature? e.g. light up some indicator when ANY secondary function triggers, or a $onSecondary trigger macro?
For that it might be worth to define a macro for each key to have exactly the color you want. Then you can have different colors for different time-outs.
I have colors for the one-hold keys I use, so I can see if a one-hold is still active. For example for the one-shot shift everything turns green and then goes back to functional lighting.
