I have both the V1 and V2 versions of UHK.
The V2 model tends to have a significantly higher daily temperature compared to the V1.
I often notice the warmth emanating from the V2.
I wonder if the RGB lighting contributes to this. Besides turning off the RGB lights, are there any other ways to reduce the temperature?
Currently, my configuration is set to the default settings.
As supposed, the temperature of your UHK should directly correlate to the brightness of the LEDs, as the LED driver IC generates the heat.
