UHK80 Mouse Layer and Mouse Modules Don't Work on Bluetooth
Hi, I have a UHK 80 with firmware 12.3.2 with both the key cluster and trackpoint modules. When using either USB Cable or Dongle connection to my Mac or Linux PCs the keyboard works correctly.
However, when trying to connect to bluetooth on either device any mouse operation does not work. This includes the entire mouse layer (controlled using keyboard keys) and the trackpoint itself. Worth nothing however is that the two buttons on the trackpoint module still work provided they are not mapped to a mouse operation.
Is there something which I should be doing differently?
Thanks
Please let’s continue at Mouse doesn't work on Android · Issue #1069 · UltimateHackingKeyboard/firmware · GitHub and share your findings there.
It’d help to test this on as many operating systems as possible.
