UHK-80 very unstable
I recently received a UHK-80 to replace my older UHK-60. I’m quite pleased with the quality of the hardware. However, the firmware seems quite unstable in comparison.
Periodically, the UHK just locks up and refuses to send any keystrokes. Sometimes it’s only the left half that locks up; sometimes it’s both (potentially this is only the right half locking up and refusing to forward keystrokes from the left?). Usually, this happens while the keyboard is idle, and the problem is simply the inability to type. However, once or twice it’s happened while I’m typing, resulting in a key release not being sent and thus that key being (logically) stuck down and repeating.
I’m connected via USB, and using the bridge cable between the halves. However, I do have batteries in both halves. Simply disconnecting and reconnecting does not usually fix the problem, since the keyboard remains powered by the battery. When the right half is failing, sometimes it shows an exclamation mark icon next to the caps and numlock icons. In any of these cases, I usually have to press the reset button on the back of the keyboard to get it working again.
These issues occurred both with the firmware that was current at ship time (can’t remember which version), and after my recent upgrade to 12.3.3.
I have a key cluster module and trackball module attached, both of UHK-60 vintage (the same ones I previously used on the UHK-60). I don’t know if this is related, but I can’t update the firmware on those modules, and the firmware version for them is still 10.5.0. When I run a firmware upgrade through the keyboard, it upgrades both halves of the UHK-80 but does not apparently affect the key clusters.
As for reliability, please upgrade to 12.3.5. It is still not perfect, but should be a significant improvement over 12.3.3.
As for module version, it is fine. Uhk80 can’t upgrade module firmware yet, but it is not a problem as the module firmware hasn’t changed for ages.
I’ve now updated to 12.3.5. Will update on whether this is an improvement in stability.
Updates:
The keyboard seems somewhat more stable. Since upgrading, I’ve had two crash incidents that required resetting.
Both times, the LED display showed “Messenger message pool space ran out!” Both times were associated with plugging my USB-C monitor cable, through which the keyboard is connected, back into my laptop after travel. (The UHK-80 is plugged into USB ports on the monitor; the monitor is connected to the laptop via USB-C, and also acting as a dock.)
This is a notable improvement over before, when it would fritz out at random points occasionally even mid-typing. However, it would still be nice to have this fixed.
Yep, we know about this issue.
The cause is however unknown. I will be refactoring debug features in order to be able to gather more details about it soon.
I’ve also noticed at different times either half will lock up and go into a reset loop (even when disconnected from everything, reset, etc) that lasts indefinitely and is completely unresponsive from that point. I’ve only been able to stop it by plugging in power into either side (even though both are close to fully charged and are definitely not resetting from lack of battery).
Latest firmware, synced between dongle. Is this a known issue that’s lumped in with the general instability?
EDIT: Will try to take a video and get more info next time it happens.
No :slightly_frowning_face:.
Crashing is a “newer” issue for me with the UHK80. Up until around 12.3.x mine would just go to sleep and not wake without a power cycle. Since 12.4 that seems to be gone, but the keyboard fully crashes (gibberish on the lcd/inoperable) at least once a day. It’s a huge improvement for me, but also has a ways to go before it reaches the stability of my UHK60. Looking forward to future FW releases.
Please bear with us and remind me once we release next Agent version - we already have a code that can flush crash logs, but it uses higher UserConfig version :-(.
Not sure if this is just me, but when I updated to the latest agent, 6.0.0 and firmware 13.0.0, my UHK80 lost the default keymaps for the top row. So, the escape key, all function keys and the right side keys lost their default bindings. No big deal but thought I should report it. I just remapped and moved on.
There is already an issue about it: UHK 80 uses UHK 2 layout · Issue #2572 · UltimateHackingKeyboard/agent · GitHub
To update on this, I haven’t seen this issue for at least some weeks. I’m currently on firmware 13.0.0.
I was going to buy it even if i have uhk 60 v2 because i wanted the f keys but seeing so many issues and no wooden palm rest i think i am gonna wait for upgraded model with maybe even a rotation knob on the left top side would be nice and better quality .
@kleidaras_gr are there any specific issues that you personally would like to see resolved?
(Because this is a half year old topic, and while I am not saying we don’t have any standing issues, one can’t refrain from wondering about possible ulterior motives of this…)
yes . i want wooden palm rest as the uhk 60 v2 and i would like to know if all the problems i have seen in the forums are resolved in regards of bugs, false inputs etc …A simple google search i did "uhk 80 problems " i read in forums about those issues.Also there is no video on youtube about uhk 80 which is weird.I want to order it but these things hold me back.i wrote here because it was the first topic about uhk 80 problems.I just want to know of any pending issues/problems regarding hardware or software so i can buy it.
Currently there are no wooden palm rests for the UHK 80.
As for software, my experience is that it works absolutely reliable and functions well over USB connection (using current firmware 14.2.0).
There are some remaining issues with wireless connectivity, especially with regards to Bluetooth pairing and switching between wireless connections. But as long as you use it over USB, the UHK 80 delivers.
ok.Is the issue with the quality of the plastic wrist rest that creates bubbles resolved?UHK80 and the rubber wrist rest bubbling up - #9 by Zetaphor
I concur with Max, it’s quite stable over USB.
They’re still working on the rubber palm pad issue, unfortunately. :face_with_diagonal_mouth:
Core keyboard functionality over usb and bluetooth dongle is pretty stable. By that I mean all the Agent-configurable features, basic as well as the fancy ones. There should be no false inputs or similar issues. However the macro engine feature set is pretty large and so there may still be some issues that no one noticed yet - if you run into any, please let me know. I usually fix them within days. (Also please do bump me if it looks like we have forgotten about anything.)
We still struggle with some hid related issues, since these depend on our usb expert whose availabily is limited. This includes general ble hid function (direct bluetooth connection to host, its pairing, and then stable operation of all interfaces - it works on some OSes while it does not on others). Also some of the more obscure usb hid features are still not perfect, like suspending and waking from suspend, especially in the context of high-res scrolling.
Having said this, I am using uhk60 and uhk80 as my daily drivers without issues. The only standing issue for me is the high-res scrolling after waking from suspend with my home computer.
Of course, my account of things is a bit biased in both ways.
Unfortunately not, but when it is, replacements will be provided: UHK80 and the rubber wrist rest bubbling up - #8 by mlac
My UHK80 has been rock solid the last while. Use it mainly over USB but also BT when needed, connected to multiple devices.
MacOs and iOS devices.
