UHK 80 manual question
If one wants to find out certain things about the UHK80 where is best to look?
Things like battery life remaining per side and how to see ?
What the symbols on the display mean?
And the like.
And how to charge it etc?
As in does it need to be USB connected to each side to charge? etc
Okay, I have found the information about the charging on the battery status on the overview page. Do have remaining questions on how it charges.
If it is connected via USB to the right side and spiral to the left, does the right side have to charge fully until the left starts to charge?
On the battery status actually when it is connected now it says 10+ 92+ which I would assuming means 10% left, 92% right and both sides are charging.
However, when I remove the cable it immediately drops to 8- 78-
Seems a little strange?
IIRC, I think the accuracy of the battery levels is still being tweaked. Iā€™m pretty sure the spiral cable charges the left half at the same time though. Whether or not they charge at the same rate, Idk. The left battery is quite a bit smaller than the right.:man_shrugging:
Current indicator is just voltage interpolation - hence also the jump when power gets disconnected.
As for charging over spiral cable, I am not sure.
