Touchpad Tap no longer working after upgrade to v12
Hi
I just upgraded to v12 of the firmware and now I can’t seem to get the touchpad to register a tap any more. It was working right before the firmware upgrade and holding down on it still works just no not a tap. Have tried forcing another firmware upgrade, power cycling it, reseating it and resetting the keyboard config to default but it still doesn’t register taping on it. Not sure if I’ve missed something, it’s a bug or what.
Never mind just found the GitHub for the firmware which has the recently uploaded update v12.0.1 which fixes it.
Ah excellent. I came with the same problem and found the same solution. Thanks!
Still, on 12.2.0, tap not working on the touchpad.
Please post your UserConfig (rename it to a txt) either here or on github, and keep pestering me until I let you know my findings ;-).
(I am quite overwhelmed these days and often forget or fail to prioritize…)
@kareltucek After resetting the device configuration and upgrading to version 12.2.0 again, mouse tap works on the touchpad.
Btw. no upload of text files (.txt, .json) is possible here in this forum, only non-alterable files like image formats and pdf are allowed for upload.
