I am wondering, how do you people go around with the keyboard? I sometimes need to travel (e.g. to the office). Since the keyboard does not turn off (UHK80 at least) and cannot be turned off, it keeps working by hitting the keys in my backpack. I’ve noticed that it keeps waking up my MacBook, which is almost on fire in my backpack because of that
And btw, I am pretty sure it does wake it up even without hitting any key looking at how my MacBook’s battery suddenly drops to super low after a single night.
Do you have any remedy for that? Except for silly “disconnect the BT connection on the MacBook every time you end your work”
My UHK80 does not wake while it is connected to my macbook. (Okay sometimes it goes into deep deep hibernation and won’t wake at all but that is a different story and not connected to sleeping)
@kareltucek isn’t the light sleep macro command already implemented and available in current release firmware? I am using some combos (shortcuts) in my UHK80 config to put the keyboard in light sleep, where it ignores keypresses until I hit the combo again.
Ah yes, that’s the one I was thinking about. I mapped it to a shortcut macro, so that I have to press a key combo (5+g or 8+h) within a short time to activate/deactivate sleep.
Hi all, have there been any developments here? I’m wondering the same with regards to transporting the keyboard and it being turned on all the time in my backpack.
