Simultaneous Opposing Cardinal Directions (SOCD)
Hello,
Recently I saw new gaming feature in latest keyboard from Razer, It is called Simultaneous Opposing Cardinal Directions (SOCD), basically you don’t need to release a key and can rapidly tap the A or D key to counter-strafe with little to no effort. Apart from Razer I saw another company called Wooting that implemented this feature. So I was wondering if this feature can be implemented for the UHK too.
Regards!
It’s being discussed here: Snap Tap/Null Movement/Last Input Priority
Thank you @maexxx, I did not found it previously :slight_smile:
