My LED display on UHK60 V1 is flashing 'OUT' along with the current keyboard layout, why?
After flashing the latest firmware 14.0.1 my LED is flashing ‘OUT’ along with the current keyboard layout name. What does it mean? Keyboard otherwise appears to work as normal.
It means there is some output in the status buffer.
If you open Agent, a yellow bar should pop up. Ideally please paste the content here. Most likely it is some forgotten debugging log, but it may also be something interesting. (Either way I would like to know so that I can fix it.)
(Once you do that, you can get rid of it either by powercycling the keyboard, or by executing the clearStatus macro command.)
Have the same issue after flashing from 8.10.12 to 14.0.1
Buffer output is:
Printing trace buffer because: Looks like your uhk60 crashed.
Last EV: 0
Trace:
()()()()()()()()()()()()()()()()()()()()()()()Rebooting…######
Do you have a Touchpad module?
I have the same output, and I have the touchpad module.
What firmware were you on before the upgrade to v14.0.1?
There was a bug that was fixed way back in v12.3.4 by flashing FW with the Touchpad unplugged.
  • Fix bug that was introduced in firmware 12.3.3 and caused the firmware update on the UHK 60 to fail when the touchpad module was connected. Upgrade to this firmware version without the touchpad module connected on the UHK 60 if you’re on firmware 12.3.3.
Ignore it. It is a bug that triggers crash behavior on a normal reboot (You can tell because it ends by Rebooting…###) which is a part of the flashing procedure.
Everything is fine.
I have the same issue, “out” is flashing, but my log do not end in “Rebooting…”, I tried a cold restart of the keyboard, but that didn’t solve the issue (that is why there are multiple outputs):
Last EV: 0
Trace:
 > [  Z*  w    ' #   @# 5  f    "  V{  h     b E3b     9   o
Q i      {#lY  U      $ G | L  j  * l  #KS 7   t ;    F        D
      8       = ~ ~  tF X  v t@Y  ls   J     Q% & ) 5T`c  u #LDH
?            D, b +   A#0  x
Last EV: 0
Trace:
Z*  w    ' #   @# 5  f    "  V{  h     b E3b     9   o    Q i
8       = ~ ~  tF X  v t@Y  ls   J     Q% & ) 5T`c  u #LDH?
       D, b +   A#0  x
Last EV: 0
Trace:
{#lY  U      $ G | L  j  * l  #KS 7   t ;    F        D      8
    D, b +   A#0  x
What firmware version is it? Please upgrade to the latest (14.2.0 iirc).
