Mouse scrolling slow at PC startup
Hi everyone,
I have this weird issue that I’m sure is a good explanation to. I cannot figure it out though. It’s 3 week old 60 v2.
When I start my PC, the keyboard always have some issue with the scrolling speed using the keyboard. It scrolls insanely slow. I have to restart the PC or re-plug the keyboard for it to go back to the actual expected speed. My settings are unchanged during this buggy phase vs. re-plugging or restarting.
Settings for reference:
Anyone experienced something similar?
I believe this GitHub issue is relevant to what you’re experiencing:
Maybe you can try using the reboot macro command to reboot the UHK, instead of rebooting the PC or unplugging the cable (I haven’t tried it myself yet). Hopefully that might be a temporary workaround.
this still seems to be an issue
thanks for the suggestion for the reboot command, saves me the hassle to replug it
