Messanger message pool space ran out!
Hi all,
I had some issues with my new UHK80, but since the new firmware upgrade things have been pretty stable.
I’ve now ran into a totally new issue and I can’t seem to find anything similar mentioned on the forum.
Keyboard just stopped working i.e. the display is working, but it’s not registering any keystrokes. There is a warning symbol icon (triangle with the exclamation) showing on the keyboard’s display.
When I turned on the Agent, there’s a bunch of “Messanger message pool space ran out!” messages shown in the orange.
I reset the keyboard by pressing the Reset button underneath, and that fixed the issue for a couple of days, but I ran into the same issue again today.
I’m running the latest firmware (Release 12.3.3 · UltimateHackingKeyboard/firmware · GitHub)
Any ideas?
Sorry about it!
Yes, 12.3.3 has some problems. We know about it, you can mostly ignore it.
In the meantime I recommend to downgrade to the previous version.
I have same issue as well,
I think it is better than previous version, I will keep this version.
just press the reset button take a minutes, until new version coming
same problem
firmware v12.4.0
Yes, we are on it!
You can watch the issue at UHK80 "Messenger message pool space ran out" · Issue #1144 · UltimateHackingKeyboard/firmware · GitHub .
If you run into it often, then please help us pinpoint the problem by flashing the last mentioned debug firmware (currently tagged as 1.2) and following the instructions.
Also, steps for quick reproduction would be extremely helpful!
