Macro Recorder Mouse Clicks?
Is there a macro recorder for mouse clicks/movements? I want to create a macro for a web browser. I’ve tried the Agent but it’s too tedious
I’m sorry to say that there isn’t a macro recorder you’re looking for.
I’m unsure whether you mean macro recording when interacting via the UHK or a third-party device. The former is easier but it’d still take much work.
I mean a macro recorder shortcut so it can record movement and clicks of the mouse. Then can be played back, with the push of a button.
Similar to the macro recorder for key inputs, already on the uhk.
Making a mouse movement macro, step by step, in Agent can be tedious.
I don’t think that would work well. The keyboard has no way of knowing where your mouse pointer currently is, so the result of any “play back” of relative mouse movements would depend very much on where you start.
In my opinion, you would be better off finding a mouse record/playback tool for your host OS, and maybe just trigger that tool from some UHK shortcut keys.
thanks, that makes sense
