Macro more sensitive on UHK80?
I have used, and still use, the above macro for years on my UHK60v2. It never triggers accidentially on the UHK60 but it triggers very easy and incorrectly on the UHKv80.
Is the timeout value for the ifNotDoubleTap different for the boards?
Somewhat related, if there is a difference is there a way to determine in a Macro if you are on a UHK60 or UHK80?
(And then set the doubleTapTimout accordingly)
@kareltucek Would you help with this?
No and no to the first two questions.
As to the third, I dont think this is a macro problem (unless it can be reproduced on 12.3.x firmware with uhk60). I.e., so far I consider this still the connection reliability problem.
