Hi, I would like to use ESC in my base like this and it works.
but when switching to Super mode
I want it to be ` ~
this does not work and instead produces §
I think somehow MacOS is converting it automatically due to US keyboard layout?
Any good solution for this please, other then changing the input source? I wanna keep U.S. for programming.
I have already tried writing a macro that would write `
but it produces § anyway.
I need this especially for swapping between windows of the same type in MacOS.
Well, that screenshot shows ‘`’ on the iso key, so mapping one of the iso keys in the super layer should do the trick.
I guess you mean to get the character on the native mac keyboard from this position
and remap it to it?
I just tried that, on the native mac keyboard that key produces §
It’s not possible to input this in the UHK agent.
I have tried to capture the key and it selects this
not possible to write that char or paste it in macro
Try mapping it to | ISO
Or, if that doesn’t work, one of the International 1
to International 5
scancodes.
MacOS is different…
thank you, this works.
here is a screenshot for future visitors - don’t forget to also add LCmd modifier
