hi, since the trackpoint is only being sold as right attachment, do you think it is possible to get 6 female - female connectors so i can attach it to the left socket of my uhk? would that work?
Not sure what you mean by “6 female - female” connectors, but if you mean just connecting the uhk trackpoint module to left half via some adequate wiring, then yes, it should work with factory firmware as long as you don’t connect any module to the right side.
If you wanted to have a right side module at the same time then you would need to modify the firmware.
i counted it wrong, it’s a 5 pin connector. anyway yes, you got my idea correctly.
thanks and have a good one
ps: waiting for a uhk100
