Under Windows I would use an extra application to launch programs. If you do not mind writing a tiny simple script I suggest Autohotkey, which allows very easily to assign a hotkey to launch a specific application. The excellent included documentation shows in an example how to launch Notepad. Then in UHK you can assign that key combo to whatever key you like.
I use this script for example to have a nice display of volume control when changing volume with Win-ArrowDown/Up or Mute with Pause:
; Joe Winograd 27-Aug-2018
; for Autohotkey V1.1 (not tested with V2)
; Developed for Windows 10, but tested successfully on W7, W8.1, and W10 (all 64-bit)
; Updated with Toggle Mute feature 10-Mar-2021
; Updated with Red and Green sliders for Muted and Unmuted states 10-Mar-2021
; 2021-03-14: changed default hotkey to Win-Up and Win-Down and Pause
; added decrease parameter step to allow faster turning down of the volume
#Warn,UseUnsetLocal
#NoEnv
#SingleInstance force
SetBatchLines,-1
; begin values to change
BarWidth:="w800"
BarHeight:="h20"
BarXlocation:="x500"
BarYlocation:="y100"
BarColorMuted:="Red"
BarColorUnmuted:="Green"
BarMillisecondsToStayOnScreen:=1000 ; 1 second
HotkeyVolumeDown:="#Down"
HotkeyVolumeUp:="#Up"
HotkeyToggleMute:="Pause"
;HotkeyVolumeDown:="NumpadSub"
;HotkeyVolumeUp:="NumpadAdd"
;HotkeyToggleMute:="NumpadMult"
VolumeIncrement:=1
VolumeDecrement:=2
; end values to change
SplitPath,A_ScriptName,,,,ProgramName
Hotkey,%HotkeyVolumeDown%,VolumeDown
Hotkey,%HotkeyVolumeUp%,VolumeUp
Hotkey,%HotkeyToggleMute%,ToggleMute
SoundGet,Volume
Volume:=Round(Volume)
TrayTip:=HotkeyVolumeDown . " or " . HotkeyVolumeUp . " to adjust volume" . "`n" . HotkeyToggleMute . " to toggle mute" . "`nCurrent Volume=" . Volume
TrayIconFile:=A_WinDir . "\System32\shell32.dll" ; get tray icon from shell32.dll
TrayIconNum:="-225" ; use music note as tray icon (icon 225 in shell32)
Menu,Tray,Tip,%TrayTip%
Menu,Tray,Icon,%TrayIconFile%,%TrayIconNum%
Gui,+ToolWindow -SysMenu
Gui,Add,Progress,%BarWidth% %BarHeight% c%BarColor% vBarVal
Gui,Hide
Return ; end auto-execute
VolumeDown:
SetTimer,SliderOff,%BarMillisecondsToStayOnScreen%
SoundSet,-%VolumeDecrement%
Gosub,DisplaySlider
Return
VolumeUp:
SoundSet,+%VolumeIncrement%
Gosub,DisplaySlider
Return
ToggleMute:
SoundSet,+1,,Mute ; toggle the mute setting
Return
SliderOff:
Gui,Hide
Return
DisplaySlider:
SoundGet,MuteState,,Mute
If (MuteState="Off")
BarColor:=BarColorUnmuted
Else
BarColor:=BarColorMuted
SoundGet,Volume
Title:=ProgramName . " Current Volume=" . Volume
Gui,Show,%BarXlocation% %BarYlocation%,%Title%
GuiControl,,BarVal,%Volume%
GuiControl,+c%BarColor%,BarVal
Return
EDIT: another launcher in included in MS Powertoys
