Hi. I upgraded the UHK to the latest firmware. This caused three issues:
Upon launching the UHK Agent, the left half of the keyboard is completely absent from the keyboard map for base/mod/etc…
The touchpad module no longer works at all.
One (and only one) of the programmed cluster module keys no longer works in Linux (but works in Windows).
Please advise. Thank you.
pcooke9
December 21, 2024, 7:34am
2
What’s the exact firmware version? I had the first two issues you listed, but FW v12.0.1 resolved them for me.
reyou
December 22, 2024, 6:30am
3
me too. After the 12.0.0 update, the left click on my touchpad doesn’t work either.
12.0.1 update recommend.
ckumz
December 24, 2024, 12:16am
4
I’m on 12.1.0 and the only issue so far is that the touchpad click is now “sticky” by default? As in, with just one tap and drag it’ll get stuck in that mode until I make another click, which is kinda hard to get used to especially since I switch back and forth with a magic touchpad.
Not sure if related but it also seems that it just refuses to respect the “Hold continuation timeout” settings, it’s the same behavior on 0 or on 2000.
pcooke9
December 24, 2024, 4:29am
5
I was beginning to think it was just me.
Could you check your Two-finger-tap to right-click and see if it also gets stuck (as well as sticking to non-UHK mouse)?
I have a link to a video of it happening on my UHK here:
opened 03:12AM - 16 Dec 24 UTC
closed 06:55PM - 17 Dec 24 UTC
Today I started UHK Agent and it asked me to update. I allowed it. Then it told … me there is firmware upgrade pending (11.2.0 -> 12.0.0). I did the firmware upgrade. Udev rules were outdated, so I updated them also, following the procedure.
Then I realized that touchpad module sends no Left click on tap anymore. I tried to detach and reattach the touchpad module and left keyboard part disappears in the UHK agent. Though, when I re-re-mapped the Left Click on the touchpad module and saved the changes, left part appears again. But touchpad left click doesn't work anyway. `xev` see no click event at all.
I tried to disconnect and reconnect the keyboard with no luck.
Let me know if I miss anything obvious...
Agent version: 5.0.0
Right keyboard half firmware: UltimateHackingKeyboard/firmware: 12.0.0
Left keyboard half firmware: UltimateHackingKeyboard/firmware: 12.0.0
Key cluster firmware: UltimateHackingKeyboard/firmware: 12.0.0
Touchpad is detected, and its firmware is implemented by the right keyboard half.
Thank you!
If you can, maybe share further details on GitHub too?
ckumz
December 24, 2024, 4:48am
6
can’t repro the two finger tap. it gets stuck during tap and drag only. definitely not happening in non UHK mice/trackpad.
mlac
December 24, 2024, 6:15am
7
If there are still any touchpad issues, I encourage you to open a firmware issue and discuss the details there, guys. We can better manage it that way.
Opened a ticket myself: Touchpad troubles. · Issue #1057 · UltimateHackingKeyboard/firmware · GitHub
Can you share your user configs @ckumz @pcooke9 ? (I can’t reprosuce the problem, so there is probably something specific that is important…)
Thanks to everyone’s reply. I have 12.2 and the touchpad issues persist. However, the left keyboard map is back, thankfully. The one cluster key still refuses to work, but only in Linux. Thanks again.
What issue exactly? That touchpad doesn’t work at all?
Would you please share your user config?
Also please provide more info about the key that doesn’t work.
Which model? uhk60v2?
