In extended macros: what’s the difference between KEYABBREV keypad1AndEnd
and np1
(and similar number keys)? Do they activate different scan codes or are they just synonyms for the same key?
@kareltucek I guess you would know?
and np1
They are synonyms for the same scancode!
Is there anywhere a table that shows which KEYABBREV and which CHAR map to which scancode?
Yes! In right/src/macro_shortcut_parser.c
and those then lead to right/src/lufa/HIDClassCommon.h
Ah. Use the source, Luke. Of course.
