Key cluster scroll locks up
Randomly, the scroll wheel on the three key cluster and the Mod+trackball scroll lock up. They scroll /infinitely/ more slowly. A power cycle fixes it.
Any idea what’s going on here?
Is it specific to the mini trackball?
Sounds like High-resolution scrolling breaks on Linux when waking from suspend · Issue #1261 · UltimateHackingKeyboard/firmware · GitHub
This is on the three key cluster with the mini trackball and the full sized trackball, when the trackball used with the mod key. This happens on Windows 10, Windows 11 and SteamOS.
And mouse (layer) keys too I assume.
If so, then it is almost surely the high resolution scrolling bug.
The best workaround for now is to bind a reboot (macro command) macro somewhere where it is easy to reach.
Having this same issue on mac. I’m on 14.0.0. What firmware version are you on?
This issue is not module-specific and should be reproducible with mouse keys.
Scrolling up/down on the mouse layer works fine for me. I only have the issue with the key-cluster ball.
EDIT: Separate issue for me. Seems like a physical issue I can remedy.
Above you reported that the full sized trackball (right uhk module i presume?) works fine?
