holdKeymapLayer QVM fn4
ifInterrupted final switchKeymapLayer QVM base
ifNotKeymap QVM tapKey ;
In the above macro, I want to prevent QVM base from toggling when pressing ‘; + y’, but I can’t find a way.
The above macro is bound to which key?
It looks like it is supposed to be ;, but the question asks about a key already pressed, not to be pressed.
Anyways, in the former case the answer is ifKeyActive, in the latter ifGesture. Search the forum and the docs for them please.)
ifKeyActive $keyId.j {
ifShortcut timeoutIn 15 $keyId.k final switchKeymapLayer QVM base
else final holdKey j
ifKeyActive $keyId.k {
ifShortcut timeoutIn 15 $keyId.j final switchKeymapLayer QVM base
else final holdKey k
I use hjkl keys to move the mouse cursor.
It is more convenient to change the mode with the ifKeyActive command you mentioned.
Thanks for the hint!
ifKeyActive $keyId.leftArrow {
} // not working
How can I implement ifKeyActive for arrow keys?
