I am having some trouble implementing the vim yiw
command which copies one word as a macro for my UHK.
The way I would like to implement it is with a ifGesture
and then execute:
- Option-Left (move the cursor to the start of the word)
- Option+Shift+Right (to select the word)
- Command+c
ifGesture 8 73 final ....
The problem is that I could not find the modifier ids for command or option and I am not sure how to combine this sequence in a single macro.
