While I was setting up macros on my keyboard, I had some typos which led to error messages showing up in UHK Agent, and the display on the keyboard flashing between “ERR” and “QWM”.
How do I clear the error besides unplugging the device?
You need to use Agent to set up a macro that runs the clearStatus command, then bind that macro to a key. When you press that key, then the command is executed.
Unfortunately, you won’t be able to do that if you cannot use Agent in the first place.
@sas2uhk
Does pressing the reset button on the bottom of the keyboard while it is plugged in work to let it connect to agent? This would be a temporary reset that would revert when the keyboard is power cycled.
Also, do you know what changed to cause the errors?
