ovesh
March 20, 2024, 11:40pm
1
I just got my UHK today, trying to get used to it.
I’m using a mac.
One thing I noticed is that the Home/End modifier keys don’t work consistently to get to the start/end of the line my cursor is on. Works as expected on Slack, but doesn’t work in Firefox.
Is this a known issue? Is there a workaround?
ovesh
March 21, 2024, 1:36am
2
I guess I can continue using cmd+arrow key, but will need the extra MOD key press.
What does the “don’t work consistently” mean specifically? What do they do in firefox?
You know you can bind cmd+arrow wherever your home/end is right now, right?
ovesh
March 21, 2024, 4:04am
4
Thanks.
In Firefox, it doesn’t do anything.
That’s what I’ve done for now, but I prefer the built-in short-cut (MOD+HOME, MOD+END) because it’s only 2 keys. Otherwise I need MOD+CMD+ARROW.
Well, that sounds like a firefox issue then?
Have you tried googling it, and raising an issue with firefox devs?
I mean, you can bind cmd+arrow as a one key / action, so you can invoke the shortcut with just two keys (MOD + KEY).
ovesh
March 21, 2024, 2:16pm
6
It works with the mac keyboard.
oh, that makes sense,
Have you checked that UHK and the mac keyboard produce the same scancode? (My bet is they dont.)
