I gave the home row keys have a secondary action via the agent gui to be modifiers like left command, option etc.
However I’ve found this changes the sensitivity of the key presses when typing.
So is there a way I can have the modifier only apply if I do something like a double tap of the key and hold on the second to activate the layer hold? Or can I change the sensitivity
You mean that you are getting accidental activations of those secondary roles?
For configuration of secondary roles, please see firmware/doc-dev/user-guide.md at master · UltimateHackingKeyboard/firmware · GitHub and firmware/doc-dev/reference-manual.md at master · UltimateHackingKeyboard/firmware · GitHub .
There are multiple ways to configure secondary roles to work with alphanumeric keys.
To begin with, you may put following into your $onInit
macro:
Then hopefully writing should not interfere with secondary roles.
You can then tweak the parameters…
As to the double tap - induced config, you can do that by:
ifGesture $thisKeyId final holdLayer mod //your secondary role
holdKey f //your primary action
