Firmware 12.1.0 & 12.2.0 bugs
I am a UHK60 v2 user.
I have two issues after the recent 12.1.0 & 12.2.0 firmware upgrade.
  1. When moving the mouse cursor with the keyboard, there is no problem with direct USB connection, but when using the Bluetooth adapter, there is a delay when moving the mouse cursor with keyboard input. (To the point of being unusable.)
  2. There is a key layout bug that seems to occur when considering the UHK80 keyboard on the right keyboard. You can check it by moving the keyboard with the mouse in the agent and setting it. It occurs on the PrtScr, ScrLK, Pause keys.
The first issue is solved by changing the firmware to 11.2.0, but the agent is forced to update, so the agent is no longer usable.
P.S. Please make a Bluetooth keyboard with the UHK60 version.
The Agent auto-update issue should be addressed eventually. In the meantime you can try reinstalling the older Agent with your internet disabled, and then unchecking this option before re-enabling the internet:
https://github.com/UltimateHackingKeyboard/firmware/issues/1039#issuecomment-2550549598
@TimingSulsa Hi there!
  1. I’m sorry, but we don’t support 3rd party Bluetooth adapters. We’ll eventually release a UHK 60 that supports Bluetooth.
  2. Do you mean the Key drag and drop exchange issues · Issue #2428 · UltimateHackingKeyboard/agent · GitHub bug? If not, please elaborate.
I forgot to check the auto update box.
Thanks for letting me know.
To explain bug #2 in detail, I tested it again after updating to the latest version of agent and firmware, but I don’t see the same symptom.
It was my mistake or it seems to have been fixed.
More than that, thank you for the good news.
I’m really looking forward to the release of the UHK60 Bluetooth keyboard.
I bought both UHK60 v1 and v2, and I’m using it really well since I settled on v2.
Fighting until the day it becomes the essential keyboard for programmers!
Thanks for the kind words! According to the Release 5.0.2 · UltimateHackingKeyboard/agent · GitHub changelog, key swapping via drag and drop has been fixed in the latest Agent version.
