Is there a way to factory reset the UHK80? Unfortunately my UHK80 is largely unusable today. Especially if the bridge cable is involved and I want to see if there is a way to “start over”.
There are factory flashing scripts in agent/packages/usb.
Simpler version is to:
- flash your preferred firmware and make sure it has really been flashed to both sides
- write a fresh hardware config (advanced settings in agent, or agent/packages/usb again)
- reset and save user config
- pair halves (advanced settings in agent)
