Dongle reconnect loop
Got the dongles two even. And I tried them out but both are appearing to be stuck in a reconnect loop.
Screen Recording 2025-01-22 at 17.52.36
Both dongles show this behavior. As does the UHK 80.
Running MacBook Pro M2 Max + Apple Studio Display.
Also tried another display’s USB hub for USB A.
And directly on USB C on the macbook…
All show the same loop.
Edit: the loop in the gif is actually slower than it is in real time. Conversion make it seem slower.
Have you tried flashing the v12.3.1 firmware to the dongle, even though it’s looping? If you have enough free ports, try flashing the firmware with the dongle connected to the same PC as the UHK. Probably a good idea to connect both halves to the PC via USB as well as disconnecting the spiral bridge cable. Might take a couple tries.
I could facepalm… Should have tried that. Now it works just fine :smiley: thank you very much.
