Hi all, I’ve been trying to setup the following but can’t find out how to do it using layers.
Goal behavior:
Fn + k → Volume down
Fn + Shit + k → Mute
is trivial via the Fn layer, but I can’t figure out how to do 2.?
I’m guessing the only way to achieve this is using macros?
Thanks
Yes, only possible via macros!
Search firmware/doc-dev/user-guide.md at master · UltimateHackingKeyboard/firmware · GitHub for ifShift; the relevant scancode abbreviations should be mediaVolumeDown and mediaVolumeMute and can be found in firmware/doc-dev/reference-manual.md at master · UltimateHackingKeyboard/firmware · GitHub.
In other words, binding following macro in your fn layer should do the trick:
ifShift holdKey mediaVolumeMute
ifNotShift holdKey mediaVolumeDown
Damn, thank you so much for the super fast reply!
Just tried it out and it worked like charm.
Now I just have to find a way to creat a Shit modifier
What do you mean? You just bind regular shift in your fn layer, don’t you?
Edit: Oh, I see, if you are referring to the typo in the original post :-).
