I’ve found that Ctrl layer doesn’t work with mouse wheel. If I use Ctrl+key I see action immediately, but if I issue Ctrl+<mouse wheel> it doesn’t work immediately (Ctrl ignored), works only if I hold Ctrl for some time.
This becomes very annoying in Figma, where mouse wheel is used for canvas scrolling (up/down) and Ctrl+<mouse wheel> is used for zoom-in/zoom-out. It starts canvas scrolling for some time, then zoom-in/zoom-out.
// set backlight.strategy constantRgb
// set backlight.constantRgb.rgb 255 0 0
set emergencyKey 64
set keystrokeDelay 20
set navigationModeAction.media.left keystroke backspace
set navigationModeAction.media.right keystroke delete
set module.keycluster.navigationMode.base media
set autoRepeatDelay 500
set autoRepeatRate 20
set oneShotTimeout 0
set secondaryRole.advanced.timeout 500
set secondaryRole.advanced.safetyMargin 0
set secondaryRole.advanced.triggerByRelease 1
set secondaryRole.advanced.doubletapToPrimary 0
switchKeymap DEV
exec configureTrackpoint
From what I can see, @likern seems to be talking about a secondary role Ctrl, and probably an external mouse. A combination which the UHK cannot completely resolve on its own. I guess the best option would be an advancedStrategy with a shortish timeout to resolve to secondary.
Yes, but I have conflicts here. I need longer timeout to eliminate accidental ctrl presses (while normal typing, ctrl is bound to home row key), and shorter (immediate) timeout for figma.
I see you have ctrl bound on the mouse/caps key, which you coul use in order to get Ctrl with external mouse immediately.
In case you can program your external mouse, you may also be able to signal to UHK that it should trigger the secondary role. (Num lock / scroll lock / caps lock are sometimes used to communicate between qmk devices.)
