Best Practices for Firmware Updates
Bossman inherited my UHK60 v1 when I bought a v2. I’ve been a good user and kept UHK Agent and my firmware current. Bossman has not.
I think his firmware is 1-2 years out of date. Should I attempt an incremental firmware update by downloading older versions of Agent instead of jumping straight to the current firmware?
We both ordered a UHK 80, so I think it’d be best to update his before it comes in.
If he is happy with the feature set then no reason for upgrading.
Feel free to try to upgrade straight to the newest. In any case, I recommend 11.x firmware with 4.x Agent, as the uhk80 code yet needs to settle down a bit…
Should UHK60 users still avoid upgrades for stability since Agent 6.x is released?
I still recommend staying on 11.x unless you have specific reasons to upgrade.
Thank you
