Best adhesive to re-attach magnet to base?
I have a UHKv1, which is still as awesome as the day I got it.
Last week, the small magnet on the bottom of the left half (below the B key on my QWERTY layout) fell off. I’m looking for a good permanent solution to re-attach it. The UHK knowledgebase says the base material is ABS.
My research into “gluing metal to ABS” tells me that superglue (cynaoacrylate) or epoxy are the best options. The magnet has a small black smear of whatever adhesive was used at the factory, so I think that’s more likely to have been epoxy than superglue.
Any suggestions about the best adhesive to use to re-attach the magnet to the base of my UHKv1?
We recommend superglue.
The superglue seems to be working nicely. Thank you!
