Wish I could have a usb input for a fingerprint reader / security keys.
Any ideas on how a v1 could be modded to add an usb port? Inspired by this, I thought about adding a 2 port hub internally, wiring the connectors to the appropriate places, but I’m not finding good pcb options.
I don’t have a good idea, unfortunately. The available space is very tight, so finding a small enough USB hub PCB to be integrated into the UHK 60 is next to impossible, I’m afraid.
Looking back at that USB C mod, reckon one could wire the existing connector into these hub PCBs as a downstream input to keep the original connector functional and then add new connectors for the hub upstream / new downstream?
New connectors would probably just be wired due to space constraints, any suggestion on how to properly mount them?
