Agent on 24.04 The setuid sandbox is not running as root
Not sure if you know this, but I recently upgraded to 24.04.1 LTS and found Agent wouldn’t launch today. Apparently you need to run like this:
./UHK.Agent-4.2.0-linux-x86_64.AppImage --no-sandbox
Are you talking about Ubuntu?
Agent is not supposed to be executed on root, in which case Electron should behave as described.
If Agent only runs as root, please open an issue and include its terminal output.
Yes, using UbuntuMATE 24.04.1.
I’m not running it as root (though I did try that initially).
I’ve put in an issue with the full output, thanks.
I read today that Ubuntu halted the rollout of 24.04 because of problems with the update. Not sure if that affects Agent, but maybe?
I have much regret.
