Agent 5.1.0 having trouble installing firmware 13.0.0
I was trying to use Agent version: 5.1.0 to install the latest firmware 13.0.0 and got this strange error message:
Start flashing firmware
[DeviceService] stop poll UHK Device
[DeviceService] stopped poll UHK Device
[DeviceService] Operating system: Linux 6.11.0-19-generic x64
[DeviceService] Agent version: 5.1.0
[DeviceService] New firmware version: 13.0.0
[DeviceService] New firmware user config version: 9.0.0
[DeviceService] Firmware contains newer 9.0.0 user config version than what Agent supports
Do I need to get a pre-release agent build to be able to install this firmware?
Thanks
Naz
Yes, you need higher Agent version.
Does 13.0.0 include the v1.4 changes that are discussed in the Jiras?
If I’m not mistaken, I think “message-pool-hunt-v1.4” is part of the “Fix main loop freezes” mentioned in the FW v13.0.0 notes. I haven’t tried it yet though.
Yes.
Thanks I just installed the new agent & firmware combo from here
I love the reboot macro command! Thank you for implementing this!
