Replay macro N times
Another example is perhaps more helpful
This macro
ifShift recordMacro $thisKeyId
ifNotShift goTo 3
break
if($repeatCount == 0) setVar repeatCount 1
playMacro $thisKeyId
setVar repeatCount ($repeatCount - 1)
if ($repeatCount > 0) goTo 4
gives me this
Warning at Runtime 1/4: Unprocessed input encountered.
> 4 ~ if($repeatCount == 0) setVar repeatCount 1
where as the below one (where $zero is set to be 0 in onInit) works fine
ifNotShift goTo 3
break
if($repeatCount == $zero) setVar repeatCount 1
The macro the previous post was from is below
if($thisKeyId == 65) setVar repeatCount 1
if($thisKeyId == 66) setVar thisKeyValue 2
if($thisKeyId == 67) setVar thisKeyValue 3
if($thisKeyId == 68) setVar thisKeyValue 4
if($thisKeyId == 69) setVar thisKeyValue 5
if($thisKeyId == 70) setVar thisKeyValue 6
if($thisKeyId == 00) setVar thisKeyValue 7
if($thisKeyId == 01) setVar thisKeyValue 8
if($thisKeyId == 02) setVar thisKeyValue 9
if($thisKeyId == 03) setVar thisKeyValue 0
setVar repeatCount ($repeatCount*10 + $thisKeyValue)
Ah, I see what I did wrong during testing. I will look into it. The macros are correct.
(Also, they are just warnings. If the macros work as expected, please just ignore them.)
Had completely overlooked the fact that they are warnings. Macros do work as expected.
Thanks!
