Edit later (esp.) configuration category
I posted my config about a year ago. That has changed and I would like to update the posts, but that is not possible. Could you give the rights to edit posts in the config category without any time limit? Also for the other posts a longer edit time frame would be beneficial IMO.
Just elevated your trust level, so you should be able to edit your older posts.
(I haven’t modified global settings because I’m unsure of the wider consequences.)
@mlac Could you give me too?
@likern Done.
