Best way to have two versions of Agent
I have two UHK60v2 and am happy on the 11.2 firmware and the Agent 4.2.x
I have a UHK80 on the way and will need the latest agent.
Any thoughts on how to best approach this?
What’s your OS? On Linux I just keep the two different Agent AppImages and run either of them. I just do that from the commandline without integrating it into Application icons.
Good point I’m on a Mac, and I really should have twigged that.
Cheers, sorted.
Is there a way to do this in Windows? I’d really like to have a portable USB version of Agent, so I don’t have to install it on someone else’s PC. Even if only for making config changes. I don’t think I’d want to try flashing with a portable Agent.
I’m not very familiar with Linux, btw.
